MPast.1
Senior
April 1, 2021
Long Press on flexButton
  • April 1, 2021
  • 0 replies
  • 576 views
Hi all,
I'm trying to manage a long pression on a Flex button.
I want realize this simple algorithm:
short pression = action_1()
long pression(IE 2secons) = action_2()
I enabled clickListener over this Flex button, I configured the trigger event on "Touch" so I can start a counter to evaluate how time pass from the first pression.
I enabled then handleClickEvent to reveal when touch is RELEASED to block and reset the actual "long press" action.
But I have same problems:
  • handleClickEvent doesn't reveal the released event
  • how can I understand if the finger is moving over the actual Flexbutton? I would like to block the long pression in case user move his finger over others objects
  • Is there any other Elegant mode to do this?
