Nicholas Yunker_2
Senior
May 13, 2024
Long Period Timer PWM Setup
I am attempting to set up a timer PWM output to have a set 600s period with a variable duty cycle based on a potentiometer input using an STM32G030J6 MCU.  I've setup PWM output timers before will little difficulty but this time I'm having a difficult time calculating the Prescaler and ARR values to accomplish this long of a period.  Are the timers just not capable of doing this long of a period and I need to us a different method to create this signal?
Nicholas Yunker_2
Senior
May 13, 2024
Uwe,
I was able to figure this out before you got back to me using these equations:
PWM Freq = Fclk/((PSC + 1) (ARR + 1))
DC = CCR/ARR
I'm running the MCU at 125kHz and setting ARR at the full value of 65535, this gives me a prescaler of 1143...this results in a Period of 599.8s when using an internal oscillator.
Duty Cycle will vary with a potentiometer. I'm going to to do further testing with this tomorrow to see how good of resolution I can get out of this.
Uwe Bonnes
Chief
May 13, 2024
What resolution do you need? What amount of Jitter do you allow? You get e.g. Millisecond resolution if you set up a 1 Millisecond interrupt and set up up a GPIO Pin accordingly.  A 16 bit timer  could only run at ~100 Hz. A 32 bit time at about 7 Mhz, if  a 32 bit timer is available on GO
Nicholas Yunker_2
Nicholas Yunker_2AuthorBest answer
Senior
May 13, 2024
Uwe,
DC = CCR/ARR
Uwe Bonnes
Chief
May 13, 2024
The solution with the 1 ms ticker interrupt will have less jitter againt the 16 bit timer.
Nicholas Yunker_2
Senior
May 14, 2024
Jitter isn't a concern in my application.  I looked into the resolution and I was able to calculate it to be 16bits...the max for this MCU
Resolution(bits) = log (ARR + 1) / log(2) = log(65536) / log(2) = 16 bits.
I think this will be a good solution.  If jitter becomes an issue I'll go the 1ms ticker interrupt route.
