LL I2C Repeat Start
I'm new to the STM32 architecture so I need some help. I am using the STM32L431 mcu and I want to interface the LIS3MDLTR magnetic field sensor through I2C. According to the datasheet, in order to read from the LIS3MDLTR, a repeated start condition needs to be used.
In my application, I am using the Low -Layer (LL) APIs. I used the STM32CubeMX to setup the project and peripherals. I found an example on how to use the I2C LL library to send and receive (by polling) but I couldn't find any help regarding on how to generate a repeated start condition. Does any one now how I can use the LL library functions to set the Master I2C to generate a repeated start condition for read operation?
Note: I can't use the HAL library since I need my code to be more efficient.
