Nov 2, 2012 12:17 PM UTC
LCD UC1608 SPI S8
- 1 reply
- 1095 views
Posted on November 02, 2012 at 13:17
I have a problem with the initialization of the display AGG240128A05-FHW-R
I do not know what could be wrong. Maybe someone has an idea? code:&sharpinclude ''GLCD_240x128.h''
&sharpinclude ''STM32F10x.h'' /* GPIO_SetBits(DrivePort_B, BM1); //DelayLCD(0xFF); GPIO_SetBits(DrivePort_B, BM0); //DelayLCD(0xFF); */ //---------------------------------------------------------------------------------------------------------- void GLCD_Init(void){ //Display initialisaton volatile unsigned long int i; GPIO_ResetBits(DrivePort_B, RES); //RES=0 GLCD_delay(100); GPIO_SetBits(DrivePort_B, RES); //RES=1 GLCD_delay(100); //CD=0 wysylanie komend GPIO_ResetBits(DrivePort_B, CS); GPIO_ResetBits(DrivePort_B, CD); // SET MR TC GLCD_SPI_Transmit(0x26); // set LCD mapping GLCD_SPI_Transmit(0x3d); // set bias ratio GLCD_SPI_Transmit(0xec); // set gain & potentiometer I bajt GLCD_SPI_Transmit(0x81); // set gain & potentiometer II bajt GLCD_SPI_Transmit(0x72); // start line number GLCD_SPI_Transmit(0x40); // display enable GLCD_SPI_Transmit(0xaf); // all pixels ON - aby zobaczyc reakcje GLCD_SPI_Transmit(0xa5); /* GLCD_SPI_Transmit(0XE2); //GLCD_delay(30); GLCD_SPI_Transmit(0XEb); //GLCD_delay(30); GLCD_SPI_Transmit(0X24); //GLCD_delay(30); GLCD_SPI_Transmit(0X2E); //GLCD_delay(30); GLCD_SPI_Transmit(0XC4); //GLCD_delay(30); GLCD_SPI_Transmit(0X89); //GLCD_delay(30); GLCD_SPI_Transmit(0X81); //GLCD_delay(30); GLCD_SPI_Transmit(0X20); //GLCD_delay(30); GLCD_SPI_Transmit(0X40); //GLCD_delay(30); GLCD_SPI_Transmit(0X30); //GLCD_delay(30); GLCD_SPI_Transmit(0X22); //GLCD_delay(30); GLCD_SPI_Transmit(0XAF); //GLCD_delay(30); GLCD_SPI_Transmit(0xa5); //GLCD_delay(30); */ } //---------------------------------------------------------------------------------------------------------- void GLCD_SPI_Transmit(char cData) { GPIO_SetBits(DrivePort_B, CS); //CS=1 (ENABLE) /* Loop while DR register in not empty */ while( SPI_I2S_GetFlagStatus( GLCD_SPI, SPI_I2S_FLAG_TXE ) == RESET ); /* Send byte through the SPIx peripheral */ SPI_I2S_SendData( GLCD_SPI, cData ); /* Zgodnie z karta katalogowa najpierw trzeba sprawdzic czy bufor nadawczy */ /* jest pusty a dopiero potem sprawdzac czy SPI skonczylo nadawanie */ /* Loop while DR register in not empty */ while( SPI_I2S_GetFlagStatus( GLCD_SPI, SPI_I2S_FLAG_TXE ) == RESET ); /* Loop while SPI is not busy */ while( SPI_I2S_GetFlagStatus( GLCD_SPI, SPI_I2S_FLAG_BSY ) == SET ); GPIO_ResetBits(DrivePort_B, CS); //CS=0 (DISABLE) } //---------------------------------------------------------------------------------------------------------- void GLCD_HwConfiguration(void) { GPIO_InitTypeDef GPIO_InitStructure; //Konfiguracja GPIO SPI_InitTypeDef SPI_InitStructure;//Konfiguracja interfejsu SPI //Enable clocks //RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //GPIO A Clock //RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); //SPI Clock //GPIO config GPIO_InitStructure.GPIO_Pin = CLK | DIN ; //SPI: SCK, MISO GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(DrivePort_A, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = CS | CD | RES; //SPI: CS, CD, RES GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(DrivePort_B, &GPIO_InitStructure); //SPI1 Configuration SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;//transmisja jednokierunkowa do MCU SPI_InitStructure.SPI_Mode = SPI_Mode_Master;//Tryb pracy SPI, mikrokontroler jako slave SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;//8-bit ramka danych SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;//Stan Sygnalu taktujacego przy braku transmisji SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;//Aktywne zbocze sygnalu taktujacego SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;//Sprzetowa obsluga lini NSS(CS) SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;//Prescaler, Szybkosc transmisji SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;//Pierwszy bit w danych najbardziej znaczacy albo LSB // SPI_InitStructure.SPI_CRCPolynomial = 7;//Konfiguracja wielomianu do obliczenia CRC SPI_Init(GLCD_SPI, &SPI_InitStructure);//Inicjalizacja SPI SPI_Cmd(GLCD_SPI, ENABLE); //SPI1 Enable } //---------------------------------------------------------------------------------------------------------- void GLCD_delay(unsigned int t) { unsigned int i,j; for(i=0;i<t;i++) for(j=0;j<104;j++); } //---------------------------------------------------------------------------------------------------------- logic analyzer: #spi-uc1608
