waclawek.jan
[L4 TIM1/8] TRGO driven from the plain OCxREF or the combined OCxREFC?
  • July 6, 2018
  • 739 views
Posted on July 06, 2018 at 15:13
The TIMx_CR2.MMS2/MMS bitr description indicates it's the former (OCxREF) whereas the figure indicates it's the latter (OCxREFC)
Please clarify.
Thanks,
PS. One chapter further, the following picture probably by copy/paste contains incorrect channel nr input to the combiner - it should be OC2REF rather than OC3REF:
Vincent Onde
​Hello Jan,
I confirm the figure is correct: the signal for TRGO is the combined OCxREFC. The register definition will have to be corrected, as well as the MS33145V1 figure.
Thanks for your feedback.
Best regards,
Vincent
waclawek.jan
Thanks, Vincent @Vincent Onde​
Jan
