asterix
Keil start-up files using GNU ?
  • February 3, 2008
  • 7 replies
  • 1313 views
Posted on February 03, 2008 at 01:10
    lanchon
    Posted on May 17, 2011 at 12:20
    Hi Asterix,
    Were you able to find or make linker and startup files for codesourcery?
    Thanks!
    asterix
    asterixAuthor
    Hi all,
    I would like to use gnu compiler from codesourcery with Keil Toolchain and Ulink-Me, but I can not find any STM32 start-up nor linker files in the default installation. Thanks for your help. :-[
    Magigimix
    [ This message was edited by: asterix.magigimix on 09-01-2008 00:38 ]
    rudi
    May 17, 2011
    Hi, Did you manage to find a startup file and the linker script file, I would also like to use the GNU compiler with Keil. :( or could somebody at least point me in the right direction, as to where to get or how I could make my own?
    Quote:
    On 09-01-2008 at 00:06, Anonymous wrote:
    Hi all,
    Magigimix
    sjo
    plus default vector files
    sjo
    gcc startup files from Anglia IDEaliST
    Cheers
    Spen
    lanchon
    see an alternative here
    http://www.st.com/mcu/forums-cat-6304-23.html
    rudi
    May 17, 2011
    thanks dudes, much appreciated!!! :D :D
