Stm32User
Feb 13, 2015 4:40 PM UTC
Keil and stm32CubeMX generated USB CDC project
Posted on February 13, 2015 at 17:40
I generated a USB CDC driver using Cube MX for the STM32L0538 DISCO. This compiled and linked and connected to a PC.
I tried to send some bytes using CDC_Transmit() but I then get USB NOT RECOGNIZED.Seems to be a hardfault in the call to USBD_CDC_SetTxBuffer()
Any ideas ?
Can anyone offer any guidance on how to use these function or an example to crib ?
    mihnea95rusu
    Feb 27, 2015 3:40 AM UTC
    Posted on February 27, 2015 at 04:40
    Hey,
    I have the same problem, just on an STM32F072 Discovery board instead. Have you found a fix yet? I've contacted ST support about this, I'll post on here as soon as they respond.
    mihnea95rusu
    Mar 2, 2015 2:24 PM UTC
    Posted on March 02, 2015 at 15:24
    ST responded. They directed me to
    http://www.emcu.it/STM32Cube/STM32Cube.html
     . I still can't figure out how to do it... If anyone has implemented the CDC class on an STM32F0, please tell us how you did it!
    edward
    Mar 27, 2015 8:11 AM UTC
    Posted on March 27, 2015 at 09:11
    Did you figure out what the problem was? I'm on a STM32L053C8 Discovery board and I have exactly the same problem - usb code generated by CubeMX doesn't work, albeit the example applications from the Cube package do.
    Amel NASRI
    Mar 30, 2015 8:46 AM UTC
    Posted on March 30, 2015 at 10:46
    Did you increased the stack size (Ex: 0x2000)?
    -Mayla-
    stm32cube-t
    Jul 1, 2015 9:45 AM UTC
    Posted on July 01, 2015 at 11:45
    Fixed in MX 4.7
    The issue was PB0,PB1, PA2,PA3,PA6,PA7 not configured properly.
    mahesh
    Jul 7, 2015 5:15 AM UTC
    Posted on July 07, 2015 at 07:15
    Hi all,
    I have created  code  using CUBEMX for stm32 L0.I am able to send and receive data only one time but multiple time receive and sending is not happening . what may be the issue ..
