hajermarnissi
JTAG size
  • March 22, 2011
  • 454 views
Posted on March 22, 2011 at 11:58
JTAG size
    May 17, 2011
    Posted on May 17, 2011 at 14:29
    you
    can
    help me
    to
    give
    the
    maximum file size
    for
    flash
    in
    the
    JTAG
    ULINK
    Keil
    You could put this under your other questions which have materially the same theme.
    I'm not aware of any fundamental limits of JTAG in this regard.
    It might be limited by
    a) Software license
    b) FLASH areas with defined programming algorithms.
    Are you trying to program flash within the part, or external parts?
    Want a tool that can program the entire internal flash space, look at ST's boot loader using the serial port. The algorithm/interface is well documented, and you could write your own application if you wanted, downloading a loader to RAM to touch external flash parts.
    Or you could buy something like a Segger J-Link with it's J-Flash ARM application.
    On the cheaper side is the ST-LINK.
    If you don't have the budget to buy tools, you might have to write them yourself, or find open source solutions.
    Andrew Neil
    ''maximum file size
    for
    flash
    in
    the
    JTAG
    ULINK
    Keil''
    This has nothing specifically to do with JTAG or uLink.
    There is no direct relation to file size.
    As has alredy been explained to you, the Keil tools state how much flash & RAM is used at the end of each build.
