yoann LBY
Senior
November 3, 2017
json parser c
  • November 3, 2017
  • 677 views
Posted on November 03, 2017 at 18:02
hi,
I am looking for a json parser librairy for smt32f4.
if someone knows small librairy easy to use.
i am working with keil mdk5.0
Yoann
    November 3, 2017
    Posted on November 03, 2017 at 18:35
    Not sure restricting yourself to the STM32 is helpful, any embedded leaning solution would presumably suffice, and the limitation would be the memory footprint you can sustain.
    yoann LBY
    yoann LBYAuthor
    Senior
    November 29, 2017
    Posted on November 29, 2017 at 18:47
    hi,
    i tested
    http://www2.keil.com/mdk5/partnerpacks/
     Keil::Jansson. v2.7
    who use it?
    someone has updated library with v2.10?
    someone would have a issue with ? json_loads? json_is_object?
    json_decref should be important?
    thks
    Yoann
