andreaspiezia9
Jan 17, 2014 5:31 PM UTC
Issue with PWM TIM3 on STM32F3Discovery board
Posted on January 17, 2014 at 18:31
Hi all,
I'd like to see a PWM with my oscilloscope, but I see nothing and I can't understand why. Can you help me? Thanks in advantage <I>
int main(void)
TIM_Config();
GPIO_Configuration();
/* Infinite loop */
while (1)
void GPIO_Configuration(void)
/* GPIOB clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_2); // TIM3 Channel1 PA6 AF2
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; // Or UP for open-collector sources
GPIO_Init(GPIOD, &GPIO_InitStructure);
static void TIM_Config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
__IO uint16_t CCR1_Val = 40961;
uint16_t PrescalerValue = 0;
/* TIM3 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
TIM_DeInit(TIM3);
/* Compute the prescaler value we want TIM3 clk @8Mhz => Presc = 8*/
PrescalerValue = (uint16_t) ((SystemCoreClock) / 8000000) - 1;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 100;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
/* Prescaler configuration */
TIM_PrescalerConfig(TIM3, PrescalerValue, TIM_PSCReloadMode_Immediate);
/* Output Compare Timing Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC1Init(TIM3, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Disable);
/* TIM3 enable counter */
TIM_Cmd(TIM3, ENABLE);
</I>
    andreaspiezia9
    Jan 18, 2014 7:06 PM UTC
    Posted on January 18, 2014 at 20:06
    Probably I going to understand the problem, just a clarification if possible:
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_10) is referring to PA11 on board?
    Jan 18, 2014 11:25 PM UTC
    Posted on January 19, 2014 at 00:25
    PA11 TIM4_CH1
    andreaspiezia9
    Jan 19, 2014 8:46 PM UTC
    Posted on January 19, 2014 at 21:46
    Clive with your code my oscilloscope see: PA6 and PA7 (TIM3) 1Khz, PA11 and PA12 nothing.
    Jan 19, 2014 11:55 PM UTC
    Posted on January 20, 2014 at 00:55
    Did you make SB21 and SB22?
    PA11/PA12 are normally assigned to the USB DP/DM function.
    andreaspiezia9
    Jan 20, 2014 10:22 AM UTC
    Posted on January 20, 2014 at 11:22
    Thanks Clive.
