Issue with changing DAC Register via ST-Link
Posted on July 29, 2017 at 00:27
I am having trouble changing any DAC registers using the STLINK debugger. The processor is stopped and the DAC is configured via Cube to be DAC Out 1 with output buffer enabled and no triggering. I let the code run through the Cube generated initialization code and stop at a breakpoint. Any attempt to change a register value or bit is not successful, i.e. the value does not change.
Has anyone encountered this?
#dac_out1
