ambrose
Oct 27, 2020 2:39 PM UTC
Is there a way to overcome "pausing" during DMA Circular transfer?
Hello I am using the STM32F334 for Lighting and I have had to use the DMA to transfer duty cycle data to the PWM duty register. The DMA is set up in circular mode and there is no interrupt. The priority it set to High. But i notice this pauses between the packets. I would have expected it to have no pauses. Please how can I get rid of this? Please see the image of actual light intensity. Hope to hear from you. thanks
Uwe Bonnes
Uwe BonnesBest answer
Chief
Oct 27, 2020 3:04 PM UTC
Maybe an off-by-one error in your DMA data.
waclawek.jan
Oct 28, 2020 12:52 PM UTC
So if it's solved, please select Uwe's post as Best, so that the thread is marked as solved.
Thanks,
