RhSilicon
Lead
June 21, 2023
Is it normal for the port reset to be 100ms in the USB Host software? (Min. 10 ms, max. 20ms)
From RM0090 (Rev 19 - February 2021), page 1393:
"Host enumeration
The application issues an USB reset (single-ended zero) via the USB by keeping the port
reset bit set in the Host port control and status register (PRST bit in OTG_HS_HPRT) for a
minimum of 10 ms and a maximum of 20 ms. The application monitors the time and then
clears the port reset bit."
But apparently the time in the software is 100ms (FW_F4 1.27.1):
stm32f4xx_ll_usb.c
 * @brief USB_OTG_ResetPort : Reset Host Port
 * USBx Selected device
 * @retval HAL status
 * @note (1)The application must wait at least 10 ms
 * before clearing the reset bit.
HAL_StatusTypeDef USB_ResetPort(USB_OTG_GlobalTypeDef *USBx)
 uint32_t USBx_BASE = (uint32_t)USBx;
 __IO uint32_t hprt0 = 0U;
 hprt0 = USBx_HPRT0;
 hprt0 &= ~(USB_OTG_HPRT_PENA | USB_OTG_HPRT_PCDET |
 USB_OTG_HPRT_PENCHNG | USB_OTG_HPRT_POCCHNG);
 USBx_HPRT0 = (USB_OTG_HPRT_PRST | hprt0);
 HAL_Delay(100U); /* See Note #1 */
 USBx_HPRT0 = ((~USB_OTG_HPRT_PRST) & hprt0);
 HAL_Delay(10U);
 return HAL_OK;
stm32f4xx_hal_hcd.c:
 * @brief Reset the host port.
 * hhcd HCD handle
HAL_StatusTypeDef HAL_HCD_ResetPort(HCD_HandleTypeDef *hhcd)
 return (USB_ResetPort(hhcd->Instance));
usbh_conf.c:
 * @brief Reset the Host port of the low level driver.
 * phost: Host handle
 * @retval USBH status
USBH_StatusTypeDef USBH_LL_ResetPort(USBH_HandleTypeDef *phost)
 HAL_StatusTypeDef hal_status = HAL_OK;
 USBH_StatusTypeDef usb_status = USBH_OK;
 hal_status = HAL_HCD_ResetPort(phost->pData);
 usb_status = USBH_Get_USB_Status(hal_status);
 return usb_status;
usbh_core.c:
 * @brief USBH_Process
 * Background process of the USB Core.
 * phost: Host Handle
 * @retval USBH Status
USBH_StatusTypeDef USBH_Process(USBH_HandleTypeDef *phost)
 __IO USBH_StatusTypeDef status = USBH_FAIL;
 uint8_t idx = 0U;
 /* check for Host pending port disconnect event */
 if (phost->device.is_disconnected == 1U)
 phost->gState = HOST_DEV_DISCONNECTED;
 switch (phost->gState)
 case HOST_IDLE :
 if ((phost->device.is_connected) != 0U)
 USBH_UsrLog("USB Device Connected");
 /* Wait for 200 ms after connection */
 phost->gState = HOST_DEV_WAIT_FOR_ATTACHMENT;
 USBH_Delay(200U);
 (void)USBH_LL_ResetPort(phost);
stm32f4xx_hal.c:
 * @brief This function provides minimum delay (in milliseconds) based
 * on variable incremented.
 * @note In the default implementation , SysTick timer is the source of time base.
 * It is used to generate interrupts at regular time intervals where uwTick
 * is incremented.
 * @note This function is declared as __weak to be overwritten in case of other
 * implementations in user file.
 * Delay specifies the delay time length, in milliseconds.
 * @retval None
__weak void HAL_Delay(uint32_t Delay)
 uint32_t tickstart = HAL_GetTick();
 uint32_t wait = Delay;
 /* Add a freq to guarantee minimum wait */
 if (wait < HAL_MAX_DELAY)
 wait += (uint32_t)(uwTickFreq);
 while((HAL_GetTick() - tickstart) < wait)
STM32H7 (FW_H7 1.11.0)
stm32h7xx_ll_usb.c
 hprt0 = USBx_HPRT0;
 HAL_Delay(10U);
 return HAL_OK;
waclawek.jan
waclawek.janBest answer
Yes. The USB specification states, that
> The reset signaling must be driven for a minimum of 10ms (TDRST).
(USB2.0 7.1.7.5). There is no maximum specified.
waclawek.jan
