Gpeti
Senior
May 25, 2020 8:13 AM UTC
Invalid voltage level on STM32H743 at reset
I'm using several Nucleo-H743ZI boards. At reset (reset handler) the bit ACTVOSRDY in PWR_CSR1 is 1 on one board and 0 on the other. 0 means "voltage level invalid, above or below current VOS". The current VOS is of course the default one at reset, ie. VOS3.
The Nucleo is powered through the STLink USB port.
Jumpers configuration on the boards are identical and I think are correct (I checked JP1 and JP3).
The problem is that, on the board where the voltage is invalid, I cannot change the voltage scaling in order to reach maximum frequency. More precisely, when I write bits VOS in PWR_D3CR (to switch to VOS1), VOSRDY is never set. On the other board where ACTVOSRDY is set at reset, there is no issue.
On both boards LDOEN is 1 and BYPASS is 0.
Moreover the Reference Manual says : "As long as ACTVOSRDY indicates that voltage levels are invalid, the system is in Run* mode, write accesses to the RAMs are not permitted and VOS shall not be changed."
Does it make sense ?
