ybenharim10
Interrupts with C++
  • December 28, 2008
  • 6 replies
  • 1099 views
Posted on December 28, 2008 at 04:48
Interrupts with C++
    ybenharim10
    Posted on May 17, 2011 at 12:57
    I generated the UART interrupt example and it worked OK.
    Since I want to write C++ code, I changed the project's language to Extended C++.
    Now I have the following problems:
    1. when building the project, the compiler produces in file stm32f10x_vetor.c:
    warning: variable ''__vector_table'' was declared but never referenced.
    2. when linking, the map file does not link the stm32f10x_vector.o and the stm3210x_it.o.
    The .intvec section is mapped to cstartup_M.o ...
    ybenharim10
    I am using IAR5 IDE.
    16-32micros
    What is your compiler/Linker ?
    Cheers,
    STOne-32.
    picguy
    I was unable to create C++ mangled symbols in IAR's assembler. Thus you are forced to use C++ to generate the vector table. Or better, simply make your C++ ISR entry point “C� style. That's what I did in a similar situation.
    16-32micros
    refer to this link :
    http://www.st.com/mcu/forums-cat-6124-23.html
    This may be helpful. The best is to contact your IAR local support.
    Cheers,
    STOne-32.
    ybenharim10
    Thanks, it seems that adding the extern ''C'' to the definitions in stm32f10x_vector.c solves the link problem
