Interrupt service routine and C++
Hey everyone,
I'm working on the STM32F4DISCOVERY with CoIDE 1.6.0 in C++. I have an interrupt on TIMER4 overflow, and so I put the interrupt service routine (void TIM4_IRQHandler(void) {}) in the main.cpp. But if I just do that it doesn't work as I end up in theDefault_Handler. I figure out it was like the routine was not found in execution. So I put extern ''C'' around my routine
#ifdef __cplusplus
extern
''C''
#endif
void
TIM4_IRQHandler(
void
#ifdef __cplusplus
#endif
And it worked. But now I can't use C++ code in this routine whereas I'd like to get the instance of a singleton in it. I'm stuck, would you have some solution or workaround ? Thank you very much :)
