javadpoostini
Interrupt Management
Posted on June 16, 2016 at 13:17
Hello Everyone
I am trying to run my code on stm32f4, with use of interrupt routines. I have an 9dof imu including mpu6050,hmc588,bmp058. So i am interfacing 3 EXTI rsubroutine to read imu and this has been successfully done. I also have gps module and pc rs232 interface to recieve data from user on pc. (usart tx is in while (1)). So i have 2 usart IRQ.
The problem now, is with NVIC. EXTI routines preempt serial port routines so that i can not read gps absolutly and also rs232 (tx,rx) hangs after some time.
What is the manner to manage interrupts?
I have used two kind of coding and none of them has worked correctly as i expect;
1 - nvic_set()
2 - nvice settings (preemption and sub) while ibitializing peripherals.
How can i manage to avoid unwanted interrupt preemption?
What is the way of managing interrupts ? How can i learn more?
Thanks .
    Amel NASRI
    Posted on June 16, 2016 at 16:01
    Hi M.J
    I recommend you refer to the
    http://www.st.com/content/ccc/resource/technical/document/programming_manual/6c/3a/cb/e7/e4/ea/44/9b/DM00046982.pdf/files/DM00046982.pdf/jcr:content/translations/en.DM00046982.pdf
    (STM32F3, STM32F4 and STM32L4 Series Cortex®-M4 programming manual). It can help you to understand how to handle interrupts with Cortex-M4 products and provides more details about preemption as well as the management of NVIC.
    -Mayla-
