Interfacing H7 usb port to Infineon CYW4373 under FreeRTOS
We will be using STM32H723 + FreeRTOS in our system and I am hoping to integrate Infineon's CYW4373 as the Wifi/BT controller.
I am to connect to the CYW4373 using USB instead of SDIO+UART, as I am running out of pins on the H723 and using USB will save me many pins. However, I have not found any driver/firmware support for this configuration. Can someone help point me to where I can learn more about this configuration?
Thank you in advance for any help!
Ed
