frankfrank9
Interface 1.8V STM32 to 3.3V SD Card?
  • February 18, 2011
  • 4 replies
  • 1105 views
Posted on February 18, 2011 at 19:26
    frankfrank9
    Posted on May 17, 2011 at 14:25
    I might add....
    Current frontrunner solution is the TI TXB0108.
    Kuikui
    What you're looking for is a called a ''voltage level translator''.
    You just have to be sure it meets your requirements ( In or Out ( or both ), speed, voltage levels, etc ... )
    aqueisser
    We're using the TXS0206 for the same purpose.
    frankfrank9
    Thanks for the pointer to the TXS family. With its internal pullups it looks like the TXS0108 will be a better fit than the TXB0108.
