CTabo.1
Senior
June 10, 2024
Integer overflow modes on Cortex
I am dealing with fixed-point arithmetic calculations on STM32G0.
To avoid integer overflow risks I have scaled properly all the values involved in calculations, but a mistake can be always possible...
On Texas Instruments DSPs, I have the possibility to switch the integer overflow mode, from wrap to saturate, thanks to a couple of intrinsic instructions.
Is there such a possibility also on Cortex processors (and in particular on Cortex M0+)?
Thank you,
Carlo
mƎALLEm
mƎALLEmBest answer
There is no saturation support in M0 /M0+ core but I think it's supported by other Cortex-M like M33:
https://developer.arm.com/documentation/100235/0004/the-cortex-m33-instruction-set/saturating-instructions
mƎALLEm
CTabo.1
CTabo.1Author
Senior
June 10, 2024
Thank you @mƎALLEm.
So there isn't an hardware support on Cortex-M processors to switch the integer overflow from wrap mode to saturate mode, like TI.
It must be handled by software...
Regards,
Carlo
mƎALLEm
mƎALLEmBest answer
