MMett
Nov 5, 2018 2:47 PM UTC
Installation problem Openocd on linux for STM32 processors
I installed openocd for debugging STM processors according to this blog: https://www.carminenoviello.com/2015/07/13/started-stm32f746g-disco/
(Building OpenOCD).
It worked fine on my old workstation, as it did on my laptop. On my new workstation I can compile and install openocd. But if I want to start openocd:
openocd -f '/path/to/stm32f7discovery.cfg'
I get a error:
/usr/local/bin/../share/openocd/scripts/target/stm32f7x.cfg:155: Error: invalid command name "stm32f7x.dap"
in procedure 'script'
at file "embedded:startup.tcl", line 60
at file "/home/ARM_LINUX/stlink3/openocd/tcl/board/stm32f7discovery.cfg", line 12
at file "/usr/local/bin/../share/openocd/scripts/target/stm32f7x.cfg", line 155
Does anyone know how I can fix this?
    Andreas Bolsch
    Andreas BolschBest answer
    Lead III
    Nov 5, 2018 3:26 PM UTC
    Probably a mixture of old files and new version of openocd, had same problem some days ago.
    I'd suggest to uninstall openocd first and check for any leftover cfg files, remove the sources, re-fetch and re-build.
    BTW Might be more appropiate to post this to openocd mailing lists?
    Andreas Bolsch
    Lead III
    MMett
    MMettAuthor
    Nov 5, 2018 5:27 PM UTC
    Thank you Andreas! This solved my problem, and saved a lot of time for me! To be honest, I didn't know exactly where to ask the question. This forum made the most sense to me. How does it work with the Openocd mailing lists? I've never read about it before.
