Inquiry Regarding STM32F407G-DISC1 Target Support for Simultaneous Reading and Writing
I am reaching out regarding a query about the STM32F407G-DISC1 target. Upon reviewing the datasheet, I noted that it indicates the target does not support reading while writing. However, upon personal experimentation, I found that it functions correctly in this regard.
Could you kindly provide clarification on this matter? I am curious to understand why my observations differ from the information provided in the datasheet.
Thank you for your attention to this matter. I look forward to your response.
mƎALLEm
mƎALLEmBest answer
STM32F407 does not support dual bank feature while for example STM32F42xxx and STM32F43xxx do.
mƎALLEm
Are you talking about the Reading while Write to the Flash memory?
yes reading while writing in flash memory
mƎALLEm
Ok but you need to provide more details about this statement ..
I am currently working on implementing a full Firmware Over-The-Air (FOTA) project on the STM32F407G-DISC1 target. As part of this project, I am considering dividing the flash memory into two banks.
My primary query pertains to whether the STM32F407G-DISC1 supports executing code from bank1  while writing to another bank2
mƎALLEm
mƎALLEmBest answer
