ugkmen
Input Floating
  • December 25, 2008
  • 600 views
Posted on December 25, 2008 at 09:38
Input Floating
    ugkmen
    ugkmenAuthor
    Posted on May 17, 2011 at 12:57
    Hi!
    I have MCBSTM32,
    This board has PB8..PB15 pins which are connected to leds.
    When i configure the PB pins as Input Floating, the leds are on. WHY?
    Is it wrong that ''Input Floating'' means ''not connected''?
    16-32micros
    Look at the board schematics at from Keil
    http://www.keil.com/mcbstm32/mcbstm32-schematics.pdf
    you will see that the LEDs are connected to IC6 - 74LVC244. I let you explain what you observe by yourself with some googling at this IC :-).
    Cheers,
    STOne-32.
