JJohn.3
Mar 7, 2021 6:40 PM UTC
Independent watchdog timer is not accurate
Here is my source code:
 void CLOCK(void){
 RCC_DeInit();
 RCC_LSICmd(ENABLE);
 RCC_HSEConfig(RCC_HSE_ON);
 while(RCC_WaitForHSEStartUp()==ERROR);
 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
 FLASH_SetLatency(FLASH_Latency_2);
 RCC_PLL2Cmd(DISABLE);
 RCC_PLLCmd(DISABLE);
 RCC_PREDIV1Config(RCC_PREDIV1_Source_HSE,RCC_PREDIV1_Div1);
 RCC_PLLConfig(RCC_PLLSource_PREDIV1,RCC_PLLMul_8);
 RCC_PLLCmd(ENABLE);
 while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)!=SET);
 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
 RCC_HCLKConfig(RCC_SYSCLK_Div1);
 RCC_PCLK1Config(RCC_HCLK_Div2);
 RCC_PCLK2Config(RCC_HCLK_Div1);
 while (RCC_GetSYSCLKSource() != 0x08){}
int main(){
 unsigned long int counter;
 CLOCK();
 GPIOS();
 IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
 IWDG_SetPrescaler(IWDG_Prescaler_32);
 IWDG_SetReload(500);
 IWDG_Enable();
 while(1)
 counter=counter+1;
 Print(counter);
 if(counter>6553500){counter=0;}
 IWDG_ReloadCounter();
I have set my watchdog counter to 500( .
second)(Stm32f107, LSI=40Khz,Prescale=32 ). By ignoring the "IWDG_ReloadCounter(); " (I commented //IWDG_ReloadCounter();) , this watchdog resets my MCU after about 3 seconds instead of .4 seconds. I need what my problem is.
waclawek.jan
waclawek.janBest answer
Mar 7, 2021 8:19 PM UTC
Is this SPL? What do those function do? Do they wait until the status register indicates the writes are finished?
Try one call of IWDG_ReloadCounter() just after IWDG_Enable(), before while(1). Does it make any difference?
Uwe Bonnes
Chief
Mar 7, 2021 7:13 PM UTC
Look in the datasheet for the tolerance of LSI. For F072 it is 30 min, 40 typ, 50 max kHz. But your error 0.4 vs 3 points to errors in your code. For me it does not make sense...
JJohn.3
JJohn.3Author
Mar 8, 2021 2:55 AM UTC
Thank you very much for your comment.
waclawek.jan
JJohn.3
JJohn.3Author
Thank you very much, it works fine. I really appreciate your help.
