In-application programming over CAN BUS
So we are checking a solution based on STM32F4 family (in this case) ARM MCU.
We have found an Application Note (AN) for the In-Apllication Programming (IAP) for Ethernet, UART and even USB, but nothing for CAN Bus.
In the AN there is a statment that the CAN BUS can be used for IAP.
Is there any AN with an example for the IAP with CAN?
