Jalal Sadigli
Image processing in c
  • November 11, 2017
  • 828 views
Posted on November 11, 2017 at 18:12
Hello
i want to learn image processing with stm32f4 in c,
*where should i start?
*do you have any suggestion?
    November 11, 2017
    Posted on November 11, 2017 at 21:33
    Understand C, thoroughly.
    Understand how data, and image are represented in memory.
    I might also suggest doing it on a PC first, where you have a file system, can read/process image files, or videos, and generate output. Debug and become comfortable with what you are working with, and what is required to handle data real-time.
    S.Ma
    Principal
    November 12, 2017
    Posted on November 12, 2017 at 13:42
    Image processing would be advanced level on a microcontroller.
    As Clive said, start from a PC, maybe experiment on a linux based solution (RPI or else), then dig down to embedded.
    For embedded, hunt for a discovery with camera example (if possible with display) as it may help you avoid startup from scratch. Otherwise, audio processing would be a better start before going '2D' with graphics.
