Akark.2441
Nov 28, 2019 10:50 AM UTC
IDS01A4 (Sub-GHz RF) connect with STSW-WMBUS-GUI (wM-Bus demo suite) - "Error fetching hw ID�?
I am using IDS01A4 (Sub-GHz RF) and F401RE. I am trying connecting with STSW-WMBUS-GUI (wM-Bus demo suite).
I follow the instructions from QuickStart.pdf
I have downloaded on the devices the binary file that I have found from STM32CubeExpansion_SUBG1_V3.1.1->projects->application -> WMBusStandalone.
I have started the program. When I push the connect button, on the right of screen received this message: “Ready
               Connected
Could you please tell me what this problem is and how I will fix this issue?
Thanks,
Andreas
laski
Dec 2, 2019 9:43 AM UTC
I have same issue and couldn't find any solution. Have you found something?
Regards Maciek
Akark.2441
Dec 15, 2019 2:48 PM UTC
You can use the binary file from STM32CubeExpansion_SUBG1_V3.1.1\Utilities\CLI\Binary\SPIRIT\<select file accroding your board>.
I have transferred this binary file on my board and it connect, but I am not sure if it works properly.
Please check and inform me if it works.
Regards,
Andreas
Ayden
Nov 19, 2021 9:28 AM UTC
I figured out how to solve it.
Modify it as below in command.h file.
#define HARDWARE_ID "S2-LP"
Regards,
Ayden
