chaugen
Dec 19, 2007 6:43 PM UTC
IAR Linker Format for ST Flash Loader
Posted on December 19, 2007 at 19:43
    chaugen
    chaugenAuthor
    May 17, 2011 10:20 AM UTC
    Posted on May 17, 2011 at 12:20
    What is the correct IAR linker output file format for the ST Flash Loader. The flash loader will only recognize .bin, .hex and .s19 file extensions. I have tried Intel standard, intel extended, Motorola S19 and others with no success. Either the linker cannot create the file due to the memory map > 64K or the flash loader cannot read the file correctly.
    16-32micros
    Hi chaugen,
    You can try with this for intel format or just a raw binary for .bin.
    Hope this helps you. :)
    chaugen
    chaugenAuthor
    That's the missing information I needed.
    Thanks!!
