IAR external SPI_FLASH(W25Q128) download algorithm
Please give an example of IAR external SPI_FLASH(W25Q128) download algorithm for STM32F429IG, thank you
November 30, 2024
Check what documentation and examples IAR provides for .flash and .mac implementations
HXNAuthor
At present, it is modified on the download algorithm provided by IAR, and now it can be downloaded to external FLASH, but it does not jump to the main function. Attached is my project, including download algorithm and test project, please help me modify it, thank you
November 30, 2024
What doesn't jump to the main() function?
The W25Q128 is on SPI4
PE4 CS
PE2 SCK
PE5 MISO
PE6 MOSI
Your function,if it's running properly should read 100 bytes into a buffer, and then loop.
Does any of that run?
Any other code you've written run?
