Ricardo Hassan
May 2, 2018 5:18 PM UTC
IAR Embedded Workbench ARM register view
Posted on May 02, 2018 at 19:18
In the latest versions of IAR Embedded Workbench (8.22.X), I am no longer able to view any of the peripheral registers.  I used to do this in the 7.X.X versions using the Registers window, but now I can only find the Current CPU registers.  Does this feature still exist in the latest IAR EW, and if so how do I find it?
Ricardo
    Szymon PANECKI
    Szymon PANECKIBest answer
    Senior III
    May 2, 2018 6:18 PM UTC
    Posted on May 02, 2018 at 20:18
    Hello Ricardo,
    IAR Embedded Workbench v.8 allows to see the content of MCU's peripherals registers.
    From main menu please select View -> Registers -> Registers1. As a result you will open Register window. Inside this window please make a right mouse click. You will see a pop-up menu. From this menu you can select peripherals. Below I attach a picture, which shows it:
    Szymon
    Szymon PANECKI
    Senior III
    Hello Ricardo,
    Szymon
