greg_t
IAP - PC side
  • October 21, 2010
  • 4 replies
  • 684 views
Posted on October 21, 2010 at 21:30
IAP - PC side
    Andrew Neil
    Posted on May 17, 2011 at 14:12
    the XMODEM and YMODEM specifications are available & free on the net, and it's not hard to write your own implementation.
    http://www.lmgtfy.com/?q=xmodem+ymodem+protocol+specification
    Most serial coms libraries will include X- and/or Y-MODEM...
    Andrew Neil
    One of the main reasons for using YMODEM (or XMODEM) is that just about every terminal program suports it.
    So you can use any terminal program you like (provided it has YMODEM).
    See:
    https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Hyperterminal%20is%20not%20the%20only%20terminal%20program
    lowpowermcu
    Hi Andrew,
    I have discovered that in the available version in ST site, it is mentioned
    ''To use the IAP, the user must have a PC running HyperTerminal or other Terminal program that supports ymodem protocol. In this document the HyperTerminal is used.''
    regards,
    MCU Lüfter
    Andrew Neil
    I know - that is a really stupid, misleading, and unhelpfulthing that it says!
    Sorry, the forum broke the link I posted earlier - try this one:
    https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/Hyperterminal is not the only terminal program!!&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&currentviews=260
