Manish Sharma
Jun 27, 2018 3:32 AM UTC
I2C Timing Calculation
Posted on June 27, 2018 at 05:32
Hi Everyone,
I am working on I2C to sense DAC data. I generated the code using STM32CubeMX. It gives timing in hex format i.e.
'hi2c2.Init.Timing = 0x10707DBC;'. It does confuse me that how does it calculate timing ?
I don't know the formula behind this timing value. I need to know it to setup my own timing.
Regards,
Manish
#i2c-analysis #stc3115-i2c-issue-timing #i2c-setup #i2c-timing-register
Jun 27, 2018 10:54 AM UTC
Posted on June 27, 2018 at 12:54
Hello
manishsharma3134
Which board are you using?
May be the '
https://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-standard-peripheral-library-expansion/stsw-stm32html
for STM32F3xxxx and STM32F0xxxx microcontrollers' can help you.
With Regards,
Imen.
Manish Sharma
Jun 27, 2018 1:09 PM UTC
Posted on June 27, 2018 at 13:09
Hi
DAHMEN.IMEN
Sorry for my bad. I forgot to mention board name. I am using STM32H753-Eval board.
Regards,
Manish
