dliky2
I2C slew rate limiter
Hello everyone,
Is there a setting/command to limit the slew rate of I2C signals of a STM32F429ZI-Disco board? I know this feature is available on some Microchip micro-controllers.
Thank you.
Peter BENSCH
Peter BENSCHBest answer
Essentially, for each GPIO and thus also for the I2C pins, you can set the maximum output speed between Low/Medium/High/Very High, which has a direct influence on the slew rate.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
dliky2
dliky2Author
Yes it does! Thank you Peter.
