gil23
I2C Slave Example
Posted on April 27, 2014 at 19:56
Hi I'
m working on STM32F401 disco EVB with the
Standard Peripherals Library
Where i can find a working example on I2C slave?
    munger
    Posted on May 05, 2014 at 03:43
    You can download STM32F4xx_DSP_StdPeriph_Lib_V1.3.0 here:
    http://www.st.com/web/catalog/tools/FM147/CL1794/SC961/SS1743/PF257901
    Mike
    munger
    Posted on May 05, 2014 at 23:14
    Yay! I've got this working pretty well. My biggest problem was that the address of the sensor is x48 and I know it is 7 bit but I did not realize that it needs to be left justified before I call I2C_Send7bitAddress. So, I need to send a x90.
    My last remaining problem is that the register I'm reading is 16 bit and I can't quite figure out how to use the std periph library functions to clock in that second byte. I don't need to send the bus address again or the register address, just need to clock in 8 more bits.
    Code looks like this after it gets the high byte.
      /* Receive high byte of Data */
      data_high = I2C_ReceiveData(I2C1);
    // Read low byte of Data
      /* Prepare an NACK for the next data received */
      I2C_AcknowledgeConfig(I2C1, DISABLE);
      /* Test on I2C1 EV7 and clear it */
      timeout = ADT7410_TIMEOUT_MAX; /* Initialize timeout value */
      while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
        /* If the timeout delay is exeeded, exit with error code */
    if ((timeout--) == 0)
    return ERROR;
      /* Receive the Data */
      data_low = I2C_ReceiveData(I2C1);
    // Build 16 bit data word
    *read_data = (uint16_t) data_high;
    *read_data <<= 8;
    *read_data += (uint16_t) data_low;
      I2C_GenerateSTOP(I2C1, ENABLE);
      /* return the read data */
      return SUCCESS;
    but it times out and I don't see that second transfer on the scope so I must not be calling I2C_CheckEvent correctly or something like that.
    I'd appreciate any ideas.
    Mike
