Vikas1
Aug 13, 2021 12:04 PM UTC
I would to generate option byte file in hex format
@Exmple:
:020000041FFFDC
:01F800000007
:020000041FFFDC
:01F80200FF06
:020000041FFFDC
:01F80400FF04
:020000041FFFDC
:01F80600FF02
:020000041FFFDC
:01F80800FF00
:020000041FFFDC
:01F80A00FFFE
:020000041FFFDC
:01F80C00FFFC
:020000041FFFDC
:01F80E00FFFA
:00000001FF
I was able to do the same in F series with the help of STVP tool, but in G0 series it is not possible.
Aug 13, 2021 1:06 PM UTC
Which STM32G0xx part specifically
I think the G0 have the Option Bytes at 0x1FFF7800 rather than the 0x1FFFF800 range this HEX data shows for the F0 series, total 16-bytes
It might be possible to array similar records for the G0 series.
Typically an erase, and rewrite all type operation, right?
waclawek.jan
Aug 13, 2021 8:35 PM UTC
Cubeprogrammer supports this?
Aug 13, 2021 9:00 PM UTC
Not sure, not using G0 here, but Keil typically has a "Flash Algorithm" for the option byte memory when programming the devices.
