Gautham Y.T
I would like to use functionalities like sine, cosine etc in my code without using math.h library.
  • October 12, 2018
  • 3900 views
Please provide me the solution for this.
AvaTar
Senior III
October 12, 2018
Use the math lib, or implement a table-based interpolation yourself.
Consider an integer-based solution.
You did not even mention the MCU you are working with.
Andrew Neil
Why do you want to avoid math.h ?
Have you looked at: https://www.keil.com/pack/doc/CMSIS/DSP/html/group__groupFastMath.html
Did you do any research yourself?
eg, google found this: https://digital.library.unt.edu/ark:/67531/metadc283001/
See also: https://en.wikipedia.org/wiki/CORDIC
