inotec
I want to change source formatting of if statements from the top example to the bottom example shown. I want the brackets to align with the if, i.e. same column..
if (SW1Pressed_F && (!SW1ActionTaken_F))
   DesiredSpeed = 10;
    DesiredDirection = LEFT;
   DesiredSpeed = 10;
    Peter BENSCH
    Peter BENSCHBest answer
    Formatting the source code can either be done by the editor, or many GUIs already contain it. The STM32CubeIDE, for example, is able to apply such formatting as an Eclipse variant with so-called profiles. Some profiles are already predefined, but you can also modify them and save or export them under your preferred name.
    By the way, exporting a profile is very useful because you can import the exported profile into new installations with just a few clicks.
    How to reach the Formatter:
    • Windows > Preferences > C/C++ > Code Style > Formatter
    or a little shorter:
    • Windows > Preferences > [type filter text] --> formatt
    Modify an existing profile:
    • within the Formatter via New > [new profile name] + select the profile to be used as a template
    • Adjusting the 65 million parameters (after that it is clear why Export is extremely useful)
    • Export
    • save with OK
    Export:
    • within the Formatter via Edit > Export
    Perhaps my Kernighan&Richie-derived Quick'n'Dirty profile (attached) will be of interest to you and could serve as a template.
    /Peter
    inotec
    inotecAuthor
    Note that the forum messed up my columns in the example, but my statement is correct.
    inotec
    inotecAuthor
    Trying again...
    DesiredSpeed = 10;
    DesiredSpeed = 10;
    inotec
    inotecAuthor
    Nope, screwed it up again
    July 15, 2022
    You can a) Edit your posts see V icon in upper right corner of posting, b) use the code posting tool </> icon, or c) post a picture or bitmap mountain/sub icon
    Something like this?
    	DesiredSpeed = 10;
    inotec
    inotecAuthor
    Yes, but without the lines before the brackets:
    if (SW1Pressed_F && (!SW1ActionTaken_F)) { DesiredSpeed = 10; DesiredDirection = LEFT; }
    1. if (SW1Pressed_F && (!SW1ActionTaken_F))
    2. {
    3.
    4. DesiredSpeed = 10;
    5.
    6. DesiredDirection = LEFT;
    7. }
    July 19, 2022
    Aren't there tools like Uncrustify that can apply any kind of formatting template you want?​
    Peter BENSCH
    • Export
    • save with OK
    Export:
    /Peter
    inotec
    inotecAuthor
    Thank you for the response. Very helpful.
    Peter BENSCH
    Great!
    If the problem is resolved, please mark this thread as answered by selecting Select as best under your preferred answer. This will help other users find that answer faster.
    /Peter
