mehmet.karakaya
May 31, 2011 7:38 PM UTC
I want my TIM4 interrupt, interrupt TIM6 ISR- how ?
Posted on May 31, 2011 at 21:38
I want my TIM4 interrupt, interrupt TIM6 ISR ?
with this configuration I cannot
  /* Enable the TIM4 gloabal Interrupt */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Enable the TIM6 gloabal Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM6_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
    May 31, 2011 9:47 PM UTC
    Posted on May 31, 2011 at 23:47
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); is a global setting, set it once, prior to initializing the individual sources.
    Your code looks reasonable. What's not happening?
    Are you initializing the timers properly, what about the service routines?
    Suggest you create a minimal demo that just does the TIM4 and TIM6 initialization and service routines.
    lowpowermcu
    Jun 1, 2011 8:06 AM UTC
    Posted on June 01, 2011 at 10:06
    Hi Clive,
    I think that mehmet should use priotity group 1 in order to get the preemption with
    preemtion priority equal to 0 for TIM4 and equal to 1 for TIM6. I think that using this config TIM4 can preempt (interrupt) TIM6. Isn't it ?
    Priority group has no preemption  priority !!!!
    mehmet.karakaya
    Jun 1, 2011 8:33 AM UTC
    Posted on June 01, 2011 at 10:33
    hello thank you ,
    my TIM4 is counting encoder pulses from servo motor
    I am building an variable named enkoder for position information
    which is updated in TIM6 ISR which is setup to 1 milisecond period
    but just during this line     enkoder=counterhi+TIM4->CNT;
    sometimes the TIM4->CNT updates but counterhi is old value and there is about 10000 count difference in enkoder value and the motor gives overcurrent and stops becouse of speed control loop -
    I catch this with following line
        if (labs(enkomem-enkoder)>500)      enkoder=counterhi+TIM4->CNT;
    however still 10000 difference becouse I think TIM4 ISR doesnot interrupt TIM6 ISR
    this happening every 1 or 2 minutes
    void TIM4_IRQHandler(void){
        if(TIM_GetITStatus(TIM4, TIM_IT_Update) == SET){
        TIM_ClearFlag(TIM4, TIM_FLAG_Update);
        TIM_ClearITPendingBit(TIM4, TIM_IT_Update);
        uint16_t current = TIM4->CNT;
          if ( current < 5000 ) counterhi += 10000; // Roll over in upwards direction
          else counterhi -= 10000;// Roll over in downwards direction
    void TIM6_IRQHandler(void){
     TIM_ClearFlag(TIM6, TIM_FLAG_Update);
     TIM_ClearITPendingBit(TIM6, TIM_IT_Update);
        enkoder=counterhi+TIM4->CNT;  at this point every 1 , 2 minute TIM4->CNT updates but counterhi doesnot
        speed = (enkomem-enkoder)*6;
        enkomem = enkoder; }
    hello lowpowermcu,
    can you please type the code sample for your suggestion
    Jun 1, 2011 11:20 AM UTC
    Posted on June 01, 2011 at 13:20
    Ok, so you have a race condition.
    So you'll want to have different preemption levels AND take steps to actively identify and mitigate the situation.
    Personally I might achieve that by giving TIM6 higher priority, storing the prior value of the high count, clearing the TIM4 Update as the last operation (ie AFTER the compare, increment/decrement), and checking the TIM4 update state in TIM6
    choky_ndhie27
    Oct 13, 2011 11:33 AM UTC
    Posted on October 13, 2011 at 13:33
    Hello clive1,
    I
    want to run
    a
    servo
    using the
    STM32
    Discovery
    if
    you
    have a
    suggestion
    program to
    run
    the
    servo
    or
    you have a
    simple
    code to
    run the
    servo
    on the
    STM32
    Discovery
    Thank you
