PMina.2
October 25, 2022
I use STM32H735 and her backup memory at 0x3880_0000 (4KB). All works OK if I use SCB_CleanDCache_by_Addr(0x38800000, 4096) after a write. Is it possible to disable dcache in this area ?
  • October 25, 2022
  • 0 replies
  • 705 views
I tried to configure MPU using standard configuration generated.
I tried this code
MPU_Region_InitTypeDef MPU_InitStruct;
HAL_MPU_Disable();
/* Configure the MPU as Strongly ordered for not defined regions */
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.BaseAddress = 0x00;
MPU_InitStruct.Size = MPU_REGION_SIZE_4GB;
MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.SubRegionDisable = 0x87;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
HAL_MPU_ConfigRegion(&MPU_InitStruct);
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
and other
MPU_InitStruct.BaseAddress = 0x38800000;
MPU_InitStruct.Size = MPU_REGION_SIZE_4B;
and adding an other region, but it does not work.
Tried also SCB_DisableDCache.
Have you got some suggestion ?
Thanks for your time and support.
Best regards,
Paolo
