Sbhus.1
August 12, 2020
I tried programs with STM32F103C8 like ADC reading etc with MXCUBE. I would like to know how to program 16x2 LCD using MDK-ARM V5
  • August 12, 2020
  • 3 replies
  • 950 views
August 12, 2020
Half the task is wiring it up properly, the other is configuring the pins and porting in an existing​ example that drives the controller on the specific 16x2 panel in question. You could also code from the manual/datasheet of the display/controller, cycling the control and data pins as diagramed.
prain
August 12, 2020
Tilen majerle have a good library for that:
​https://github.com/MaJerle/stm32fxxx-hal-libraries/tree/master/15-STM32Fxxx_HD44780
Nikita91
Lead II
August 12, 2020
