sG.12
I'm Working on CAN protocol. Its worked good in loopback mode . but while executing in normal mode it will show dominant bit error.
using STM32f103c8t6 and transceiver MCP2551. This transceiver working well in with other controllers.
January 22, 2019
Still think you need to review transceiver, wiring, speed and bus traffic.​
sG.12
sG.12Author
already checked everthing..speed 1Mhz, terminate with 120 ohm
January 22, 2019
So is the controller wrong about the error? Have you confirmed the signal integrity with a scope or analyzer?
sG.12
sG.12Author
only checked using ST LINK debugger.
Jack Peacock_2
If loopback works then the first thing to look at is how the other node is configured, especially the bit timing. Check the timing on your other node and make sure the STM32 matches it.
Is your timing crystal based or an RC oscillator? RC based timing has considerable drift, especially running at a 1MHz bus rate.
Jack Peacock
sG.12
sG.12Author
Crystal based. 8Mhz
