pvall.1
Feb 28, 2023 6:48 AM UTC
I'm working on ADC (12 bit) in NUCLEO-L4P5ZG board. In that the ADC value is correctly showing Upto ADC_IN_10 channel, afterwards it is showing random values for channel 11-15 what might be the reason?
Feb 28, 2023 9:11 AM UTC
Hello @pvall.1​,
What values/ ranges are you getting?
Could you provide more details about the context, which ADC, ADC clock, using DMA?
You may also need to check if the ADC channels 11-15 are enabled in the code and properly configured
pvall.1
pvall.1Author
Feb 28, 2023 9:46 AM UTC
Hi Sarra.S,
We are using 12 bit ADC with 3.3v Reference voltage, so the values are in range of 0 to 4095.
Settings of ADC are as follows
ADC mode:Single -ended
Prescalar :Asynchronous clock mode divided by 4.
Yes,ADC channels 11-15 are enabled properly.
Feb 28, 2023 9:51 AM UTC
Hello again @pvall.1​
Make sure that the ADC clock is running at the correct frequency
Also, are you using your own design ?
pvall.1
pvall.1Author
Feb 28, 2023 9:54 AM UTC
It is running at correct frequency as we are getting values for remaining channels,I'm not understanding why is it not working for remaining channels.
Yes,I'm using own design.
