bassem.saleh93
I have trouble writing to flash using HAL_FLASH_Program in case of FLASH_TYPEPROGRAM_DOUBLEWORD option.
I have the code working fine with the 1byte, 2bytes and 4bytes programming, reading and writing. But when I use the 8Bytes (double - word), It is always trapped in a hard fault handler. Any help?
berendi
Principal
October 23, 2019
Which MCU is that? Does its reference manual (flash program operations chapter) say something about the specific requirements for 64 bit programming operation?
