NRAML.1
I am using STM32H723 for my project, I plan to create a scatter file for the mapping area but I couldn't found any Memory Mapping explanation on the provided data sheet or programming guide. Does anyone know where I can refer the memory Mapping
TDKBest answer
December 17, 2021
The Reference Manual has the map of memory regions and is the best source of info for the chip. See "Memory map and register boundary addresses".
https://www.st.com/resource/en/reference_manual/dm00603761-stm32h723733-stm32h725735-and-stm32h730-value-line-advanced-armbased-32bit-mcus-stmicroelectronics.pdf#page=132
Seems like a lot of work when you can just use existing solution for this. Your IDE of choice should have a solution.
TDKBest answer
December 17, 2021
NRAML.1
NRAML.1Author
Thank you for your help. I got the answer for my question.
I am using KEIL for this project, Yes I can use the existing solution for the memory mapping.
