k239955_stm1_stmicro_com
HSE osc 4-16MHz or 1-25MHz
  • December 25, 2008
  • 3 replies
  • 914 views
Posted on December 25, 2008 at 05:09
    Posted on May 17, 2011 at 12:57
    Hi All,
    Does anyone know whether the HSE osc range is 4-16MHz or 1-25MHz. Datasheet (4-16MHz) and user manual (1-25MHz) indicates two different values.
    Thanks,
    Kerem
    16-32micros
    Hi Kerem,
    If you look carefully in the datasheets, you will see that both are correct : See table : ''High-speed external user clock characteristics'' & table ''HSE 4-16 MHz oscillator characteristics'' : Let me explain this :
    In the first case, you provide a clock signal with an External Oscillator, in that case STM32 can run up to 25Mhz, in the second case you provide just a (quartz+ 2caps) or a resonator and the oscillation is done internally by the embedded High Speed Oscillator, in that case STM32 can run from 4Mhz to 16Mhz.
    Hope this is helpful :)
    Cheers,
    STOne-32.
    Ok. I understand. Thanks for the input. Terminology mislead me. The manual says 1-25 MHz OSCILLATOR. So I thought it was the oscillator. Anyhow it is clear now. Thanks.
    Kerem
