kalpeshpatil102
Jan 16, 2017 4:09 PM UTC
How to used internal EEPROM(read and write operation) of STM32L011F3?
Posted on January 16, 2017 at 17:09
Hi, i am using STM32L011F3 . I am using cube mx and keil mdk 5 ide for programming. In my project I want to write and read  data on internal  EEPROM of stm32L0 11F3.
I didn't get any library or example tutorial for this . I am new in stm32L011F3 .
please help me.
thank you
    Jan 16, 2017 5:18 PM UTC
    Posted on January 16, 2017 at 18:18
    Hello
    Patil.Kalpesh,
    I recommend you to have a look to the "Flash program memory and data EEPROM (FLASH)" section in your related STM32L0 product reference manual
    http://www.st.com/content/ccc/resource/technical/document/reference_manual/21/bd/0f/bd/1c/88/40/f0/DM00108282.pdf/files/DM00108282.pdf/jcr:content/translations/en.DM00108282.pdf
    and get idea about read-write from EEPROM.
    You can have a look to this example under
    http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubel0.html
    which describes how to configure and use the Flash to enable and disable the write protection of the internal FLASH memory:
    STM32Cube_FW_L0_V1.7.0\Projects\STM32L031K6-Nucleo\Examples\FLASH\FLASH_WriteProtection
    You can inspire from this example to achieve your goal and modify it or add your own code.
    Also, you can found a full set of running examples with a EEPROM under ST web page within other STM32CubeXX firmware package (like STM32CubeL4), which can help you as an implementation example to build your application on L0.
    Imen
    Jan 16, 2017 5:58 PM UTC
    Posted on January 16, 2017 at 18:58
    Isn't the EEPROM just mapped into regular address space, can't you read it using pointers, or memcpy() ?
    kalpeshpatil102
    Jan 17, 2017 9:05 AM UTC
    Posted on January 17, 2017 at 10:05
    thank you @ DAHMEN.IMEN, Turvey.Clive.002 for reply.
    I go through STM32L0 product reference manual
    http://www.st.com/content/ccc/resource/technical/document/reference_manual/21/bd/0f/bd/1c/88/40/f0/DM00108282.pdf/files/DM00108282.pdf/jcr:content/translations/en.DM00108282.pdf.
    on page no. 822 found write function like this '
    Write to data EEPROM code example
    *(uint8_t *)(DATA_E2_ADDR+i) = DATA_BYTE;
    *(uint16_t *)(DATA_E2_ADDR+j) = DATA_16B_WORD;
    *(uint32_t *)(DATA_E2_ADDR) = DATA_32B_WORD;
    DATA_E2_ADDR is an aligned address in the data EEPROM area. i can be any integer. j must be an even integer. */*/
    in this function i wrote like this
    /*/*/* write function of eeprom write/*/*/*/*/*/*/**
    unsigned long int DATA_E2_ADDR=8080100;// EEPROM address of stm32L0
    int i=0,j=0, DATA_BYTE=3;//
    but didn't get it working or not . and how to perform read operation ?
    let me know where i am wrong ?
    please some one give example on internal eeprom read and write function that will helpfully for me.
    sorry for poor English
    please help me .
    thank you
    Jan 18, 2017 4:57 PM UTC
    Posted on January 18, 2017 at 16:57
    One has to be careful with the Cortex-M0 as it doesn't not support unaligned memory operations, it will Hard Fault. ie reading a 32-bit value from an odd address
    I'm not using the L0, my expectation is the FLASH writing examples will be a good place to start.
    For reading I'd suggest using structures, either with pointers to them, or copying the content to a RAM holding buffer using memcpy()
    You are familiar with typedef, struct and memcpy(), right?
    kalpeshpatil102
    Jan 18, 2017 2:58 PM UTC
    Posted on January 18, 2017 at 15:58
    Hello , thank you to all. please any one can give  simple example  to write and read data on internal EEPROM of stm32L0.  please help me .
    thank you
    Alan Doncaster
    Jan 19, 2017 12:27 PM UTC
    Posted on January 19, 2017 at 13:27
    Hi Patil
    This works for the STM32l051 on Eclipse, just migrating to Keil so haven't tried it on that yet:
    #define DATA_EEPROM_BASE_ADDR ((uint32_t)0x08080000) /* Data EEPROM base address */
    #define DATA_EEPROM_END_ADDR ((uint32_t)0x080807FF) /* Data EEPROM end address */
    Simple write sequence:
    void Write_Registers_to_Eeprom(void)
    uint32_t i;
    uint32_t* p_tFlashRegs;
       i = 0;
       p_tFlashRegs = (uint32_t*)&data_to_write;   /* Point to data to write */
       UnlockEeprom(); /* Unlock the EEPROM and enable flash interrupts */
       FLASH->PECR = FLASH->PECR & ~(FLASH_PECR_ERASE | FLASH_PECR_DATA); /* Reset the ERASE and DATA        bits in the FLASH_PECR register to disable any residual erase */
       /* Put the next line in a loop if sequential bits to be written with i as loop counter */
       EepromProgram(DATA_EEPROM_BASE_ADDR + (4 * i), *(p_tFlashRegs + i)); /* Increase eeprom address by 4 for each        word to write.  */
       LockEeprom(); /* Lock the EEPROM */
    Called routines:
    /* Unlock the EEPROM: */
    void UnlockEeprom(void)
       while ((FLASH->SR & FLASH_SR_BSY) != 0) /* Wait for FLASH to be free */
    /*   insert timeout test */
       if ((FLASH->PECR & FLASH_PECR_PELOCK) != 0) /* If PELOCK is locked */
          FLASH->PEKEYR = FLASH_PEKEY1; /* Unlock PELOCK */
          FLASH->PEKEYR = FLASH_PEKEY2;
       FLASH->PECR = FLASH->PECR | (FLASH_PECR_ERRIE | FLASH_PECR_EOPIE); /* enable flash interrupts */
    * Brief This function programs a word of data EEPROM.
    * The ERASE bit and DATA bit are cleared in PECR at the beginning
    * words are automatically erased if required before programming
    * Param addr is the 32-bit EEPROM address to program, data is the 32 bit word to program
    * Retval None
    void EepromProgram(uint32_t addr, uint32_t ee_data)
    /* NOTE: The EEPROM must be unlocked and the flash interrupts must have been enabled prior to calling this function.*/
       *(uint32_t *)(addr) = ee_data; /* write data to EEPROM */
       __WFI();
       if (*(uint32_t *)(addr) != ee_data)
          error |= ERROR_PROG_32B_WORD;
    /* Lock the EEPROM: */
    void LockEeprom(void)
       FLASH->PECR = FLASH->PECR & ~(FLASH_PECR_ERRIE | FLASH_PECR_EOPIE); /* disable flash interrupts */
       FLASH->PECR = FLASH->PECR | FLASH_PECR_PELOCK; /* Lock memory with PELOCK */
    To read you can use a simple structure (eg called Eeprom_registers) and have something like:
    #define CONFIG ((Eeprom_registers *) DATA_EEPROM_BASE_ADDR)
    then get data using something like
    Eeprom_data1 = CONFIG-> xxxx ; /* where xxxx is the entry in the Eeprom registers */
    either that or something like
    Eeprom_data1 = *(uint32_t *)(addr); /* where addr is the EEPROM address you want to read */
    Hope this helps.
