How to use X-CUBE-SPI-EMUL?
Posted on June 07, 2018 at 17:33
I'm hardware engineer and I'm starting to work with the STM32 µC family so I don't know the environment.
I'm already start a project with CubeMX. I need for my project at least 6 SPI and I use the STM32F407 (only 3SPI). So I have found a firmware package driver to emulate SPIs : X-CUBE-SPI-EMUL
But this 'driver' can't be implement simply in my project. I've just found a example project.
Is there a simple solution to use as a driver?
Thanks in advance,
Best regards
Olivier
