CYong
Aug 24, 2018 3:26 AM UTC
How to use LCD MIPI DSI LP Mode to initialize LCD?
Hi Sir,
I used STM32F469i-DISCO for evaluating my project.
I now TRY LCD which driver IC is ST7701S and show some image in video mode at panel.
ST7701s had to initialized in DSI LP Mode. I had referenced STM32Cube_FW_F4_V1.21.0 example projects. But I can't make it work. Could you please provide example which is including DSI LP mode configuration for me?
Environment : STM32F469i- disco and ST7701s LCD.
I had implement some LPCmd before HAL_DSI_Start(), but it doesn't work.
LPCmd.LPGenShortWriteNoP  = DSI_LP_GSW0P_ENABLE;
 LPCmd.LPGenShortWriteOneP  = DSI_LP_GSW1P_ENABLE;
 LPCmd.LPGenShortWriteTwoP  = DSI_LP_GSW2P_ENABLE;
 LPCmd.LPGenShortReadNoP   = DSI_LP_GSR0P_ENABLE;
 LPCmd.LPGenShortReadOneP  = DSI_LP_GSR1P_ENABLE;
 LPCmd.LPGenShortReadTwoP  = DSI_LP_GSR2P_ENABLE;
 LPCmd.LPGenLongWrite    = DSI_LP_GLW_ENABLE;
 LPCmd.LPDcsShortWriteNoP  = DSI_LP_DSW0P_ENABLE;
 LPCmd.LPDcsShortWriteOneP  = DSI_LP_DSW1P_ENABLE;
 LPCmd.LPDcsShortReadNoP   = DSI_LP_DSR0P_ENABLE;
 LPCmd.LPDcsLongWrite    = DSI_LP_DLW_ENABLE;
 LPCmd.AcknowledgeRequest  = DSI_ACKNOWLEDGE_DISABLE;
 HAL_DSI_ConfigCommand(&hdsi_eval, &LPCmd);
I observe through the oscilloscope, DSI always in HS mode.
Many thanks!
    CYong
    CYongBest answer
    Sep 20, 2018 3:56 AM UTC
    this issue was closed. the root cause is vendor issue.
    CYong
    CYongAuthorBest answer
    frackers
    Senior
    Feb 20, 2019 3:40 AM UTC
    Which vendor - the LCD or STMicro ?
    I'm having a similar problem and more information on a possible solution would be very helpful.
    SSabo.1
    Jun 26, 2020 6:27 PM UTC
    Hi Friends,
    Can anyone provide me driver files for ST7701s ??
    ari_v2
    Senior
    Mar 16, 2021 9:55 AM UTC
    Hi SSabo,
    I'm looking for a driver for ST7710s. Did you find it? Could you please share it?
    Thanks,
    Ari
