How to trace STM32H7B3I-EVAL instructions with segger J-Trace Pro
I have downloaded the trace example from segger website https://wiki.segger.com/STM32H7#Tracing_on_ST_STM32H7B3. However, it doesn't work out of box due to the board does not have trace pins connected to the debug header by default. Have anyone tried this before and make it works correctly? If so, could you please share the solution how to set the solder bridges? Thanks for your help.
