manes69692
how to swith to 72Mhz ?
  • February 1, 2009
  • 3 replies
  • 870 views
Posted on February 01, 2009 at 06:15
    manes69692
    Posted on May 17, 2011 at 13:01
    Hi
    I trying to switch my board to 72Mhz , but I think I do something wrong , because I'm also using usart1 at 9600bd , but my baudrate is not correct
    When just turning on my external xtal of 8Mhz , the baudrate is correct.
    What is the correct sequence for switching to pll ?
    Best Regards ,
    Ronny
    BTW this is the code I'm using :
    // switch to 72MHz
    RCC_CR=0x00010083; //enable the 8Mhz crystal
    while (!(RCC_CR)&0x00020000); //wait for hse ready
    RCC_CFGR=0x00000001; //set the 8Mhz crystal as clock source
    RCC_CFGR=0x00010001; //set the 8Mhz crystal as pll source
    RCC_CFGR=0x001d0401; //pll*9
    RCC_CR=0x01010083; //enable the pll
    while (!(RCC_CR)&0x02000000); //wait for pll locked
    RCC_CFGR=0x001d0402; //set pll as system clock source
    manes69692
    Quote:
    On 31-01-2009 at 19:05, Anonymous wrote:
    Hello, I am using this initialization sequence, it works for both 48 and 72 mhz:
    http://chibios.svn.sourceforge.net/viewvc/chibios/trunk/demos/ARMCM3-STM32F103-GCC/board.c?revision=634&view=markup
    Just look at the hwinit0() function.
    The various constants are defined here:
    http://chibios.svn.sourceforge.net/viewvc/chibios/trunk/demos/ARMCM3-STM32F103-GCC/board.h?revision=703&view=markup
    regards,
    Giovanni
    Thanks Giovanni !
    Your code works perfect , I'm gonna figure out now , what I did wrong
    Thanks again
    Ronny
    disirio
    regards,
    Giovanni
